This is a gen 5 Camaro with a twin turbo setup. I can get the car to do everything right, but the fueling is wildly inconsistent. Seems that the longer I drive the car the leaner it will get. On a cold start I sometimes have to add 60% of fuel to get it to start and idle, then over the next the couple of flashes I have to pull all of that fuel back out.
Once I get the car drive-able and the AFR looking good, (especially after getting into boost a couple of times) the AFR will creep lean to the point that it will not idle and stumbles.
Here is the weird part, If I stop and reflash the PCM (with the exact same tune) it totally changes. It will then go back to however it was before, but alas, if I drive it some distance (5ish minutes), the AFR goes back lean only to be fixed by reflashing the exact same tune once again.
Car is in open loop and all the fuel cut, modifiers, etc. are turned off. Nothing should be acting on the fueling. I'd point towards something IAT, ECT, etc., but that wouldn't explain why it immediately goes back to right after I flash it with the same exact tune up. It also wouldn't explain that whatever tune up worked good the night before, requires such a massive amount of additional fuel just to get started the next morning.
One interesting note is the super low Cyl Airmass I am seeing, even with A LOT of boost I only make it down to about .60 g/cyl. I also Idle in the .08 g/cyl row.
Car is 430ci, has ID2000 injectors, twin turbos, 6speed, running on gasoline and has a ZR1 MAP.
I have tried running the car in MAF only, virtual VE, 2 bar SD O.S. and a blended model and it does it on all of them.
I have also tried running previous tunes from before the TT setup, tunes from other TT gen 5's that I have that work good, and a fresh file. All of them do the same thing. Car eventually runs like garbage from going lean.
I am going to attach one of many tunes I've tried in the car to no avail.
