Hey guys,
I have an issue that has me stumped. I just got the car all back together from the recent build, and it will not go into boost. I have been all over the car mechanically and electrically and haven't found anything that has tripped my attention. Basically what the car is doing, is when I get on the throttle to start building boost, the MAP will go up to the 105kpa-110kpa region, and then after that it breaks up real bad and stutters and wont build past that. I have tried (sketchy) to stay in the throttle a little longer a couple of times, but that wasn't getting me anywhere. The most I have made on the car is about 4psi, and I have that in a log. Was going to see if you guys had any ideas. Let me know, I sure wish I could enjoy the project i spent months and thousands on. lol
Specs:
2000 Pontiac TransAm
TH400
2 bar OLSD
370ci LQ4, AFR 225cc
Garrett 74mm T6
Siemens Deka 80# injectors
NGK BR7EFs @0.025"
Edelbrock pro-flo intake
Genuine GM Cobalt 2 bar MAP
On e85
4.3 psi and thats it.hpl
Jordan's E85.cfg
changed timing a little.hpt
