Results 1 to 10 of 10
Thread: VE table estimation
    Apr 2013
    210
    VE table estimation
    Is there a way to develop a 'rough' VE table through a properly calibrated MAF curve in a GEN III pcm?
    i'd imagine i could use fuel mass/air mass and some algebra to find VE..
    Has anyone attempted this?
    Dec 2004
    Laurel, MD
    1,020
    make a custom histogram, with MAP/RPM axis, and then for data use all the other data to calculate the VE.
    Apr 2013
    210
    Quote Originally Posted by redhardsupra View Post
    lol well thats funny, i have a red hardtop supra myself.
    either way.
    wouldn't I need to determine MAT? and if so, isnt that based off bias tables?
    can't find MAT in the GEN III stuff.
    ht.
    Jun 2007
    Finland, Europe
    549
    I guess the logic is following: compare MAF-based airflow to theoretical cylinder filling.
    For MAF isn't it so that you divide MAF grams/second value with rpm (and rpm needs to be divided with 60 to get revs/second). And this again is divided by the number of cylinders. So the end-result is measured airmass per cylinder at certain conditions. Wich then needs to be compared to the theoretical value per each MAP/rpm cell.
    In other words, you need to define a custom PID with something like this: ([SENS.40.MET]/([SENS.70]/60))/8
    ...where SENS.40.MET is MAF value as grams/second and SENS.70 is revs per minute, which is divided by 60 to ger revs per second. And 8 is obviously a number of cylinders.
    Am I right or wrong?
    Does anyone have Banish' book where the VE formula is presented? I have both books, but cannot find now either of them...
    Jun 2007
    Finland, Europe
    549
    Quote Originally Posted by cesar View Post
    ht.
    It's called IAT in GM vocabulary and right now in my Scanner configuration it seems to be [SENS.11].
    Mar 2007
    Tucson, Az.
    165
    VE = MAF / (Displacement x P stp x Speed)
    SOLD - 2005 C6 6.0 LS2,TF 235 heads, 245/255 .630 113 LSA cam, LS7 lifters, YT 1.7 RR, FAST 102 LSXR, VMax 90-102mm, VMax CNC ported TB, LS7 injectors, Dewitts radiator, Manley 7.550 pushrods, LS7 fuel pump, PowerBond 25% UD pulley, RPM stage 2 '06+ 4:10 rear end, Callaway CAI, 160* thermostat, HP Pro custom tune, LG Pro headers
    Now - 2016 C7 ZO6 A8
    Dec 2008
    on the Dyno
    1,825
    We do not have MAT as a PID in HPTuners for Gen3 stuff. At least I've not seen it as of yet. I do know the other software has this PID to log though. You would need the reported MAT to properly calculate VE. Without that your VE will be scewed using IAT only.
    On the Gen3 stuff it's much easier to go the opposite way. Dial in VE first and then generate a MAF table by overlaying dynamic airflow (while running in SD) on the MAF Freq table.
    Located in Central Kentucky
    ShorTuning
    Apr 2013
    210
    Quote Originally Posted by Pekka_Perkeles View Post
    actually theres IAT and MAT in gm vocabulary.
    Either way, LSxpwrdZ, i understand the VE would be a bit skewed due to just using IAT, but don't you think it would be better than having to start off at zero? if the IAT gives a sample error of +10% then I would more or less have to decrease the entire ve by 10 percent.
    Seems like the GMVE stuff is more appropriate for the e38's huh? since you can log mat and all.
    Jun 2007
    Finland, Europe
    549
    Ok, sorry. I just haven't ever seen it in a Gen III stuff.
    Jun 2007
    Finland, Europe
    549
    Quote Originally Posted by LSxpwrdZ View Post
    Which sensor woud it (MAT) use then in Gen III? Or is it somehow estimated/calculated?
    I've moved my IAT sensor to intake manifold, so I guess that would then act as a MAT.
