Results 1 to 6 of 6
Thread: PE mode in idle?
    Mar 2005
    Hendersonville TN
    161
    PE mode in idle?
    Just finished a cam install in a '12 ZL1. Mild cam with very little overlap. Runs great with the initial tune I have put in it but it goes into PE after sitting at idle for about 10-20 secs. AFR drops into the 12's then bounces back into 16s before coming back to 14.68 afr. Any ideas why it does this. Never happened before the cam install. Below is the scan and tune and config. See at 3:19 the event. Cam is 227/246 on 120 LS What other info would help?
    Bryan
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    Disable the cat test.
    Russ Kemp
    Mar 2005
    Hendersonville TN
    161
    "Cat Test" or "Cat Overtemp"? I thought that might have something to do with it. How did changing the cam affect it and make it come on at idle?
    Bryan
    Mar 2005
    Hendersonville TN
    161
    Disable CAT Test did the job. Still don't know why the cam change brought this problem to the surface.
    Bryan
    Jan 2012
    17
    It might have done it before but the new cam makes the motor more sensitive to the EQR change....
    Mar 2006
    DFW, Tx
    156
    Gonna have to try this....just started noticing the same thing on mine.
    2013 ZL1 A6
