Results 1 to 6 of 6
Thread: 9.6* of KR on my 1999 GTP... Not sure why
    Nov 2011
    19
    Mods are:
    3.5" MPS, 180* T-Stat, ceramic coated PLOG, 3" ZZP Catless DP, 10.5mm ZZP wires, AL104s, K&N large cone intake, ZZP Alternator Rewire.
    Using HP-Tuners, I am seeing consistent 11.0 AFR at WOT. Peaked at 9.6* of KR yesterday evening. WAYYYYY too much for my comfort. Any recommendations on what I can do or check??
    Thanks in advance
    13,565
    Post the tune.
    Dec 2008
    Old Orchard Beach Maine
    915
    Are you seeing commanded 11.0 or actual 11.0 reporting from a wideband ? usually once you see what actual afr is on a wideband and then get fueling to where your actually in the 11's problems diminish .
    Short of a wideband I would check fuel pressure with a guage on the Schrader valve of the fuel rail to see if your losing pressure due to bad pump , poor ground/voltage etc...
    a 3.5 pulley with only a plog and dp for exhaust mods will likely still see some kr but shouldn't see that much unless fueling is way off or its boost stacking , your not getting 13/14 psi are you ?
    PB's 1/4 mi 12.21 117.75 trap ,1/8 mi. 7.779 93.99trap , 1.949 short time (FWD W body)
    Tuner in Training charlieRobinson's Avatar
    Dec 2013
    27
    He's peaking at ~10psi which seems like quite a bit with a 3.5"!
    Why arent you logging your MAF Hz or AFR err %?
    I am a total noob but maybe it's a fueling issue? No way you should be getting that much KR!
    1999 Riviera L67 SII 3800
    XP HOT cam, 140# springs, Gen V swapped, 60# inj, E85
    Nov 2011
    19
    Sorry for the delay guys. Thanks for the replies!
    I do have a wideband and the ECU is commanding AFR = 11.0, and I am actually seeing 11.0-11.2 on the wideband so it is pretty much spot on. No fuel issues that I know of (injectors appear to have consistent PW and duty cycle, new fuel pump, runs just fine).
    Boost at WOT stays consistently around 10+psi which is reasonable for a healthy motor with good compression on a 3.5" pulley I believe (stock pulley is 3.8" which gives 6-7psi. Figure about 1psi added for every 0.1" reduction in pulley size, so 10psi with a 3.5" pulley is about right).
    Dec 2013
    27
    You're right about the PSI, my bad.
    Please post your high octane timing table or your actual tune. I am currently tuning with a 3.6" with what I think is high timing and close to 0 KR. I am curious to see what your tune looks like to get 9 degrees of KR.
    I was recently tuning with a 3.4" with low timing to keep the KR down. Decided to try a 3.6" tune to see what results I can get. Wish I had a 3.5" to experiment with!
