I am just starting to tune with HPT on my vehicles and want know a few things. First I have an 06 Escalade 6.0 LQ9, cold air intake, throttle body spacer, shorty headers, cat back Magnaflow system. I purchased the HPT for specific reasons and also purchased Innovative LC-2 wideband kit so my questions start:
1. With the wideband kit there are four factory o2 sensors (all read errors I believe from the headers) so to install the LC-2 as is it would only read i side of the exhaust do to dual factory pipes from the headers back to the muffler or do I need to install dual sensor kits? Also can I remove the factory sensors all together after the tune is setup and written to the VCM?
2. I also want to change to SD but upon purchasing the MAP sensor recommended (GM Parts Direct #12592525) it will not work with my intake. My MAP just has two clips, no screw holding it in place. New one has provision for one screw and clip on other side. ACDELCO Part # 213796 would anyone know if this is 1, 2, bar sensor as it is the current installed?
That's it for now, there is alot of info out there but not able to find relatively current nor specific. Thanks ahead for any help.
