So I have the Whipple SC, LS3 all stock except what comes with the whipple kit (injectors, boost a pump, etc). I also have the 2bar OS with ZR1 map sensor..
Everything's great (other than the weak fuel pump that drops pressure during WOT even with the BAP)...
Now I'm just trying to fine tune some things... Noticed my startup while warm is the only thing that needs help.. when cold (coolant temps below say 80F), it startups up great... RPM comes up to around 1900 then falls to around 1100 and is steady and sounds great.
When warm... (like when shutting off to get gas, or even after about 4hrs off on a warmish day...), when I start it, RPMs come up like normal (~1900rpm), but then it sounds like it's lean, and rpm comes down to around 400-500, then back up to ~1100rpm and things are normal.
To me it sounds lean, sometimes when getting gas when I restart after ~5mins... it will pop (sounds like a lean pop after the rpm dip... right when it re-lights and comes back to ~1000rpm).
I've played around with the "Cranking FA Mult Stage 1 vs. Cranking Time" but never seemed to improve... it only got worse so now that table is stock. I've also switched to MAF/MAP mode and no difference compared to running only MAF during startup. I then added ~15% to the VE table in that area but there was no change (so ignore the choppiness in the VE table).
To me, it looks like the Injector pulse width is very low 1 second after warm start and it's causing the problem, since RPM comes back up after the INjector pulse comes back up... any idea how to fix this?
Cold Start (Good): Frame 90, no RPM fluctuation
Warm Start (RPM unstable): From 37633
2B091b WHIPPLE_Dynamic Airflow enabled PE Enrich 1500-2000rpm.hpt
2B091 Cold and warm start.hpl
