Hello All- does anyone have a stock bin for a 2002 Silverado with 6.0 and 4l60? I check the repo and all that was there were files for a truck with 4L80. Thank you so much in advance.
All LQ4 6.0 were backed with a 4L80E that i know of, and the 5.3/4.8 were backed with a 4L60E. If you have the LQ9 6.0 (SS) then I beleive you have the 4L65E or 4L70E.
Thing outside the box. Consider other Year/Make/Model.
4.00 in bore blocks (1999–2007)[edit]
The 6.0 L is a larger truck version of the LS1, with the exception that the blocks were cast of iron, and was designed to bridge the gap between the new small blocks and big blocks in truck applications. There were two version of this engine: the LQ4 and the LQ9, the latter being more performance oriented. Although the block of the 6.0L looks similar to the LS1, they are iron instead of aluminum.
6.0 L[edit]
The Vortec 6000 is a V8 truck engine. Displacement is 6.00 L (366 cu in) from 101.6 mm (4.00) bore and 92 mm (3.622") stroke. It is an iron/aluminum (1999 & 2000 model year engines had cast iron heads) design and produces 300 horsepower (220 kW) to 345 horsepower (257 kW) and 360 lbf·ft (490 N·m) to 380 lbf·ft (520 N·m).
LQ4[edit]
The Vortec 6000 LQ4, is a V8 truck engine. Displacement is 5.97 L (364 cu in) from a 4.0-inch (101.6 mm) bore and 3.622-inch (92.0 mm) stroke . It is an iron/aluminum (1999 & 2000 model year engines had cast iron heads) design and produces 300 hp (224 kW) to 325 hp and 360 lb·ft (488 N·m) to 370 lb·ft (502 N·m). LQ4s are built in Romulus, Michigan and Silao, Mexico.2013 model year produces 360 hp
LQ4 (VIN U) Applications:
Chevrolet Express/GMC Savana
Chevrolet Silverado 2500 Pickup, 3500 Pickup, Crew Cab, and Chassis Cab/GMC Sierra 2500 HD Pickup and Crew Cab, C3, Denali, and 3500 Pickup and Chassis Cab, 1500HD Crew Cab
Chevrolet Suburban/GMC Yukon XL Denali
Hummer H2 SUT
GMC Yukon Denali
LQ9[edit]
The Vortec HO 6000 or VortecMAX is a special high-output version of the Vortec 6000 V8 truck engine originally designed for Cadillac. This engine was introduced in other truck lines as VortecMAX for 2006. It features high-compression (10:1) flat-top pistons for an extra 10 hp (7 kW) and 10 lb·ft (14 N·m), bringing output to 345 hp (257 kW) and 380 lb·ft (515 N·m). LQ9s are built only in Romulus, Michigan.
LQ9 (VIN N) Applications:
2002–2006 Cadillac Escalade
2002–2006 Cadillac Escalade EXT
2003–2006 Cadillac Escalade ESV
2003–2007 Chevrolet Silverado SS
2004–2005 Chevrolet Silverado and GMC Sierra Vortec HO Edition Only [Badging on truck](B4V)
2005-2006 GMC Sierra Denali pickup and Yukon Denali
2006–2007 Classic Chevrolet Silverado and GMC Sierra VortecMAX Option
Janky Monkey Tuning
Call or PM for tuning solutions.
Cell 210-954-4985
Wrench turning provided by 2 Tightwads Racing.
Tune your own? Start here ----> Open Editor ---> Hit F1...READ!
READ SOME MORE (Thank username 69Lt1bird): http://ls1tuningguide.com/
Still lost? Consult a Pro!
www.thetuningschool.com
www.calibratedsuccess.com
www.tunedbyfrost.com
