Results 1 to 6 of 6
Thread: Im new to HP Tuners and am Looking for help
    May 2014
    3
    Okay, I ordered HP tuners and am getting started today. I have a 70 mm turbo on a pretty much stock 5.3. It still has the MAF. I do have a 340 LPH pump With 80 lbs injectors. it has a small cam but im not sure which. I have a wide band installed and the engine does start and run but smokes like a fright train and the wide band just reads rch, or rich lol. My question is where do i start with this? What about timing, fuel, maf, i would like to get a good solid tune on this MAF then I will probably switch to a SD tune. I have been reading about this for a couple months, so im not new to terms and as far as running a new program, that should be no problem at all! Thanks in advance for all of your help!!!!
    Tuner noorjSS's Avatar
    Dec 2011
    Albany, NY
    61
    is the smoke white, blue or black?
    Start by taking 5% increments out of your entire MAF table until it's relatively 1 lambda at idle. Are you running in closed or open loop?
    Make sure you have the correct injector settings.
    2006 Chevy Cobalt SS 2.4 Turbo
    320 whp 299 wtq
    May 2014
    3
    Quote Originally Posted by noorjSS View Post
    ITs a black smoke. From fuel. I will try that. Im not sure on closed or open loop, I havent hooked anything up yet
    May 2014
    3
    Okay I can't even get the car to idle. What else should I try? It just cranks and sometimes it hits but won't stay consistent.
    Jun 2007
    Finland, Europe
    549
    Quote Originally Posted by turbo5.3ta View Post
    Put the stock injectors back and see if it runs fine.
    If so, you have found out what you need to tune when using much larger than stock injectors.
    Nov 2009
    All Around
    3,149
    post file and log if you can
