Hey guys, Been around reading stuff quite a bit on here, Im in the midst of trying to figure out what is wrong with my motor.
Lets start with the basics.
Its a stock block 5.3L vortec from a 2003 Silverado auto truck.
Intake and 0411 ecm is from a 2002 avalanche dbc auto.
Installed a manual NV3500 Transmission.
I have not changed any of the parameters for the vss and gear ratio ect.
I have a Current performance wiring harness for the swap.
Heres my issue, at idle or or under load i cant get the motor past 1500 rpm.
If i bring the throttle up and hold it at 1500 its fine, if i try to go past and hold it it drops and bounces back up continually.
Im going to be looking at the tps soon here but aside from that, is there any chance abuse mode is causing this.
