Is the ability there to turn of the check engine light even if there are codes and things like abs lights, or low coolant lights. normal lights that show on the dash. Traction control lights.
Anyone?
You can turn off the SES light with other lights on.
ABS codes arent going to set the SES off, neither will a low coolant code or something.
