Results 21 to 40 of 52
Thread: NGK AFX WITH NTK SENSOR vs Innovate Motorsports LC-1
  1. #21
    Mar 2011
    The Bush
    169
    Quote Originally Posted by LSxpwrdZ View Post
    You can have the NGK read lambda on the display... you just have to spend a little money and send the box in to ECM to re-flash the chip to show lambda instead of AFR in reference to 14.57:1 stoich.
    Ordering an AFM-1500 myself for tuning and keeping my NGK and Haltech/Daytona as backups/sanity check. I normally use my NGK in the exhaust in place of a narrowband pre-cats and then use my Haltech/Daytona in the tail pipe which is logged on my dyno to verify readings. I figure 2 readings are better than relying on one.
    More info please?
    Where to send it and roughly how much?
    Thanks!
  2. #22
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    Quote Originally Posted by yellz06 View Post
    Per the Ford Muscle article... the Innovate is the way to go... I've used it so many times with success that I wonder why change it.
    You're kidding, right? Innovate sponsored that "test".
    http://www.dsxtuning.com
    Just say no to bull s***.
  3. #23
    Advanced Tuner Montecarlodrag's Avatar
    Nov 2009
    Pegasus Galaxy
    919
    NGK AFX is still sold with both NTK and Bosch sensors, you need to be careful when buying. Cheaper units always have the Bosch sensor
    9 sec Montecarlo SS
  4. #24
    Dec 2008
    on the Dyno
    1,825
    Contact ECM to do modifications to your unit. The most accurate way to of using an AFX style wideband is get the AFM1000 and the DIS1000. The DIS1000 is just a display that you can order to be programmed to whatever stoich afr or lambda or EQ and hooks up to the AFM1000.
    The one thing I have been looking for is a large LED panel that will accept voltage input and you can program a transfer function to so that I can put up in the dyno bay to watch on a huge display while making pulls.
    Located in Central Kentucky
    ShorTuning
  5. #25
    Sep 2008
    1,668
    Quote Originally Posted by Montecarlodrag View Post
    From an e-mail to me dated 2/18/2013.
    "Hello,
    The original units several years ago came with Bosch sensors. The AFX comes with the NTK sensor 24302 now.
    Best Regards,
    Andrew Hauenstein
    Product Coordinator
    NGK Spark Plugs USA Inc"
    That's from NGK...you're only going to get one "new" with a bosch sensor if it's been sitting on a shelf for years.
    2010 Camaro SS M6. Stock Bottom End, Heads/Cam/Intake/Headers/Exhaust.
    2005 Silverado RCSB. Forged 370 LQ9/Borg-Forced Inductions T6 S484/Jake's Stage 4 4L80E with D3 Brake/4WD.
    2023 Durango Hellcat
  6. #26
    Sep 2011
    Jax, Fl
    216
    Ok so emailed ECM and for $200 they can change it to lambda, increase the range to .6-1.3L and make some changes for voltage stability. Just have to mail it to them.
    2006 Holden Monaro I Phantom Black Metallic I Red I One of 416
    L92/L76 I Streetsweeper HTR I SLP LT I LoudMouth 2
    JHP V2 I Powdercoated Black 18s I Kyne Splitter
    2001 GTP I Stock DD
  7. #27
    Mar 2008
    St. Louis, MO
    4,859
    The extra range intrigues me.
  8. #28
    Sep 2011
    Jax, Fl
    216
    Need the email address or shipping address? I'm shipping mine out tomorrow.
    2001 GTP I Stock DD
  9. #29
    Mar 2008
    St. Louis, MO
    4,859
    Yea, the email address would be nice.
  10. #30
    Sep 2011
    Jax, Fl
    216
    2001 GTP I Stock DD
  11. #31
    Mar 2008
    St. Louis, MO
    4,859
    Quote Originally Posted by Kyne View Post
    Thanks!! I have five of these that I'd like updated.
  12. #32
    Sep 2011
    Jax, Fl
    216
    Ha nice! I was thinking about buying another just to get it updated.
    2001 GTP I Stock DD
  13. #33
    Mar 2011
    The Bush
    169
    I have 2x here, will send them off one at a time, thanks Kyne!
  14. #34
    Nov 2009
    Pegasus Galaxy
    919
    Quote Originally Posted by MikeOD View Post
    "Hello,
    Best Regards,
    Andrew Hauenstein
    Product Coordinator
    Still you need to be careful. I bought one a few months ago and I saw several units with Bosch sensor, they were like 40 bucks cheaper. I noticed because of the reduced price
    9 sec Montecarlo SS
  15. #35
    Is there a way to tell the difference between the bosch or NGK units? Or are they labeled?
  16. #36
    Nov 2009
    Pegasus Galaxy
    919
    Quote Originally Posted by STR8BALLN View Post
    Bosch units are cheaper and the sensor is different. In the description of the product it should say if it has the NTK sensor
    If it doesn't say, ask the seller. Most of them make very clear their units have the NTK sensor
    9 sec Montecarlo SS
  17. #37
    Tuner JnJSpdShop's Avatar
    Aug 2005
    Western New York
    195
    I won't use anything but my AFM-1000. Best money I ever spent when it comes to tuning.
    The best part about it is the NTK sensors do not drift with age. They either work and give 100% accurate results, or it doesn't work at all. I used the same sensor for over a year tuning with it daily, before it finally died and I had to replace it. Replacement sensors are $400 for the AFM-1000 though.
    Been thinking about one of these for a while now and I think I am ready to make the jump. Is the sensor durability as good as they say it is??
    Western New York's Performance Headquarters
    716.830.0506
  18. #38
    The AFX with NTK sensor is far superior in accuracy.
    Thanks to all, I went with the AFX/NTK.
    Fedex delievered it yesterday.
  19. #39
    Sep 2011
    Jax, Fl
    216
    I sent my AFX unit to ECM on Tuesday I think. Arrived today and they already emailed me saying it's done. Quick turn around! When it gets back I'm sending my second one in as well. I should have an update next week with a review.
    2001 GTP I Stock DD
  20. #40
    Mar 2011
    The Bush
    169
    Good stuff!
    Sent one of mine off a couple of days ago but it's a bit further for me
