Page 3 of 3 FirstFirst 123
Results 41 to 52 of 52
Thread: NGK AFX WITH NTK SENSOR vs Innovate Motorsports LC-1
  1. #41
    Sep 2011
    Jax, Fl
    216
    So this upgrade/modification is called the AFM1600L. Turns the AFX into the AFM1600L. I could only find this info on the upgrade
    The error is the same as the newer AFM1000 and AFM1500 according to ECM and even the range is similar except it is shifted a little leaner.
    http://www.ecm-co.com/download.asp?11010
    2006 Holden Monaro I Phantom Black Metallic I Red I One of 416
    L92/L76 I Streetsweeper HTR I SLP LT I LoudMouth 2
    JHP V2 I Powdercoated Black 18s I Kyne Splitter
    2001 GTP I Stock DD
  2. #42
    Mar 2011
    The Bush
    169
    So roughly 8:1 <> 19:1 AFR, not bad thanks again for the heads up on this
  3. #43
    Sep 2011
    Jax, Fl
    216
    Closer to 8.75-19
    2001 GTP I Stock DD
  4. #44
    Mar 2011
    The Bush
    169
    Still better than 9>16
  5. #45
    The new NGK unit that replaces the AFX is supposed to read from AFR 9.00 to 20.00
  6. #46
    Sep 2011
    Jax, Fl
    216
    2001 GTP I Stock DD
  7. #47
    Mar 2011
    The Bush
    169
    Mine is done and on it's way back to Australia, ECM have been faultless in making this happen!
  8. #48
    Dec 2008
    on the Dyno
    1,825
    I'm glad you guy's are getting this done!! I had thought about it and think I am going to pull the trigger on another new NGK unit and send it right off to them.
    Located in Central Kentucky
    ShorTuning
  9. #49
    Mar 2011
    The Bush
    169
    13 days Door to door to door Australia>USA>Australia, awesome service, I ordered a part from one state away the day before I sent the NGK off to ECM and it hasn't arrived...
  10. #50
    Sep 2011
    Jax, Fl
    216
    Damn that's about how long it took mine, and ECM only had it a day.
    2001 GTP I Stock DD
  11. #51
    Dec 2008
    on the Dyno
    1,825
    I have a question for you guys that have the converted box's already... does the new box still do the startup voltage output routine? The original NGK at the countdown marker of 15 would output stoich voltage until the countdown reaches 5 and then it would output the minimum lambda possible which in stock form is 0.618 lambda. This becomes extremely helpful when setting up the wideband to read correctly in the scanner. You can log the whole startup process to verify lambda of 1.000 from 15-5 on countdown and then 0.618 from 5-0 countdown. I'm just curious if the new box still does a similar routine to help keep the analog output as close as possible to minimize error.
    ShorTuning
  12. #52
    Sep 2011
    Jax, Fl
    216
    Yep it does.
    2001 GTP I Stock DD
