Results 1 to 13 of 13
Thread: Random loss of power
    Advanced Tuner Niemer's Avatar
    Jul 2012
    371
    Had anyone seen this before? Steady throttle in PE and power just drops out, no loss of traction and in manual mode. GMVE, Cylinder airmass, and injector pulsewidth amongst other things just drop to 0, the attached log shows this at frame 6780. This happened twice this morning, but TC was going nuts the first time so that log is pretty messy.
    Ported TVS1900 OD cogs 10.5psi | ID850 | Vaporworx CTS-V 1:1 | COMP 219/233 .606"/.605" 113+1 | Ported TB | Pacesetter 1 3/4 LT | Solo Mach X3
    Jul 2012
    371
    Happened again this morning. There are a couple of times I entered PE in this log and the last with no issue, shows up at frame 8660
    Jul 2012
    371
    Anyone?
    Nov 2009
    All Around
    3,149
    that is strange... try logging less PID....how does the car feel?
    Jul 2012
    371
    Thanks for the reply. It feels like hitting a wall or the throttle snapping shut all of a sudden. I've switched back to MAF only and made a few changes to the trans setting and it hasn't happened again. I'll keep watching for it to happen.
    May 2014
    2
    Had issue with 2011 Silverado PE would not work in manual mode but fine in drive Dave Steck solved my problem
    Jul 2012
    371
    This same thing seems to have happened once again yesterday afternoon after being fine for quite some time. I cant seem to figure out what causes it, airflow just drops to 0, and it's not just in the scanner, it actually happens.
    Jun 2011
    Montreal, Canada
    758
    Almost looks like the TB is slamming shut, but haven't really seen that on a stock TB.... more common on aftermarkets.
    2007 Corvette C6 Vert. A6
    LME LS402, Pat G custom cam, ATI 10% OD Damper
    Circle D triple disc 2600, 3.42 Diff
    YSI, 3.0 pulley, ID 1000's
    Alky Control Meth,
    ARH 1 7/8 headers,
    1009 RWHP @ 7000, 817 RWT @ 6000
    Jul 2012
    371
    It sure feels like it.
    Tuning Addict
    Jan 2015
    6,815
    Airflow won't drop to 0 g/sec even with plate completely shut. Looks like your hitting a maf limit or wiring to maf or just bad maf... Just to verify, as long as your sd is close, put it into straight sd and duplicate conditions to see whether or not the problem is still present or not. Make sure you change to sd in tune.
    Plus unless you've killed tb dtcs, if tb were closing or loosing connections it should immediately set a dtc and rep...
    ~Greg Huggins~
    Jul 2012
    371
    This is in SD only, and open loop within a couple percent, MAF isn't even plugged in. The only DTCs that are disabled are those related to the MAF and the ones disabled for the blower, P0068 I believe.
    Tuning Addict
    Jan 2015
    6,815
    OK, you had MAF g/sec in the pic you posted and it was at 0... So watched the data log. Only saw it occur in one place. At that particular point the electronic throttle control stayed at commanded 69%. Before the complete fuel cut took place I saw both boost and delivered torque dropping. So I went to the tune and took a very brief look at the torque limits. Under Engine - Torque Management - Default Trans Limit - This is still stock 300 something. Start here and go from there. Looked like where it happened in the data log the ecm cut the fuel. Might want to add some of the other desired and actual pids to your logger to help track down the problem.
    ~Greg Huggins~
    Jul 2012
    371
    I don't know how much I want to mess with the default trans limit since it looks like it's only used when communication to the TCM is lost. I'd rather have that as a fail safe. I have all the fuel cuts, at least that I could find, disabled, so it shouldn't be cutting fuel ever. It also happens unpredictably so it's going to be a hard one to pinpoint. I'll log all of the fuel cut PIDs I can find just in case.
