Results 1 to 2 of 2
Thread: Please check this out. 3 bar sd gto
    Aug 2013
    1
    2004 gto, ls2, f1a procharger, fic 2000 injectors. new build start up.
    Jun 2007
    Finland, Europe
    549
    Adjust TPS sensor -related stuff in the Engine Diagnostics. Othewise REP is guaranteed with your setup.
    PE(BE) for boost is missing. Or actually it is 1, which is not good.
    Adjust your Min Fuel Milligrams, if it idles too rich.
    Max torque may need to be maxed out..
    You VE may bee too low in low boost areas, but you'll find that out fairly easily.
    I would totally disable Burst Knock functionality.
    I didn't check your injector data, but they probably are in the right ball-range.
    Have fun!
