So I have a LQ9 .030 over and LS3 heads a very large cam, trun. kit, valve springs, LS3 intake manifold, 92mm Fast throttle body, 90lb. fast inj., dual O44 pumps, and the works with a 03 suburban ECM. I have been having some trouble getting this thing to idle right and it will not hold a idle at all. It just stays roughly around 1700 rpm with zero throttle input. I have set my target idle speed and dialed in the new injectors. We are forcing the computer into SD mode as we plan to run boost next year. Also for the majority of the tracks we go to the weather conditions vary so much that open loop control with wide band is the way to go. Any thoughts as to why we can not get it to hold steady idle?
2014-04-04 Basemap1.hpt
