I have a 2001 Camaro SS M6 that I received. I hooked up my hp tuner cable up to it to read the tune so I could tune it and I got a 6000 error code. I did some research and it said that the car may have had a handheld tuner hooked to it at one point and had a canned tune. So I tryed pulling the radio fuse as well as cycling the key on and off and had no luck. So I did a write entire putting my buddies 2002 Camaro SS Auto tune in it and downloaded a stock Manual stune from the repository and changed ALL the parameters to match the manual tune and it runs great with everything except WOT. I goes waaaay lean at WOT. At one point I hit 4,000 rpm and it hit PE mode and went to 12.5 afr but it only did it once. Car has SLP intake, SLP MAF, SLP headers and Offroad Y pipe into SLP exhaust. I tried changing the PE tables and had no luck, Any other Ideas I could try?
jose's camaro log 1.hpl
Jose Gonzales 2001 Camaro SS Tune 1.hpt
