Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 68
Thread: 2013 Mustang VCT - idle cam position issue
  1. #21
    Nov 2009
    All Around
    3,149
    Pedal Position has nothing to do with it, you arent enabling OP VCT
    VCT has different tables that are referenced to depending on the conditions and temprature
  2. #22
    I'm working on a 2013 f150. Same deal. Op is not enabled on these things so shouldn't need changes in op. I know cam specs are different. I have mine giving correct idle speed and all but I'm gonna hold out until I'm able to log more.
  3. #23
    Sep 2008
    1,668
    Does anyone have any advice on how to do get a lumpy idle on a 2011 GT? I tried doing what's mentioned in the link to the PDF, but it seems to be idling the same...other than at a higher RPM than stock. Stock was 650, the PDF has it changed to 775.
    2010 Camaro SS M6. Stock Bottom End, Heads/Cam/Intake/Headers/Exhaust.
    2005 Silverado RCSB. Forged 370 LQ9/Borg-Forced Inductions T6 S484/Jake's Stage 4 4L80E with D3 Brake/4WD.
    2023 Durango Hellcat
  4. #24
    Just making sure with those who haven't gotten this yet...
    You're making sure vehicle is up to operating temp and oil is up to temp? I notice that my lumpy idle doesn't automatically start unless I give the throttle a tap. Once the rpm goes back to idle, the lope is engaged.
    When warming up from a cold start, as the car gets warmer you can actually hear and feel the lope come into play. Kinda cool.
    Total Masshole.
    2013 F150 FX4 Supercrew Ecoboost - STOCK
    2013 Mustang GT Premium - Lots of Mods, 424 RWHP SOLD
    2009 Cobalt SS/TC Black Sedan
    227whp/224wtq Stock. Dejon CP, K&N SRI, Forge BPV, Catless, BadMab Catless DP, MPx 3" Catback, HPT Tuned 328whp/425wtq. SOLD
    2004 GTO Pulse Red 1 of 512 - R.I.P. 5/31/09
  5. #25
    Sep 2008
    1,668
    I let it idle for about 20 minutes...revved it all the way to 6000 rpm...nothing happening when it comes back.
    Here is the stock read, and then my attempt at the tune...did I do something wrong?
    Stock.hpt
    Try 1.hpt
  6. #26
    Sep 2008
    1,668
    Well...I just found the exhaust cam phasing limit vs EOT was set to 0 in the 750 RPM cell...just changed that, going to go flash it and see if it works.
  7. #27
    Sep 2008
    1,668
    Didn't work. Here's the new file though.
    Try 2.hpt
  8. #28
    Advanced Tuner veee8's Avatar
    Apr 2006
    Raleigh, NC
    449
    I didn't have any luck with a 2014 GT A6 I tuned either. Just a higher idle, but no lope. I followed the .pdf screenshots as well.
    www.crawford-racing.com
    Home of the original and best selling CR-Fueler plug and play port injection controller kits for all GM Gen V direct injection platforms.
  9. #29
    Sep 2008
    1,668
    I tried -40 instead of 40 on the intake cam for positions 0 and 1... It sounds different returning to idle, but not loping and only for a couple seconds, then I hear a noise under the hood, which is probably the cams moving, then it idles super smooth again.
    Also, one time flashing, HPTuners said complete way way way too fast and the car was dead, wouldn't crank. Had to restart HPTuners for it to see the interface again, but luckily it took the flash without issue again and the car started. I was nervous I'd lost the PCM.
  10. #30
    Sep 2008
    1,668
    I don't understand what the distance tables are doing at all. I understand mechanically how VCT works, but I'm lost in this computer LOL.
  11. #31
    Quote Originally Posted by MikeOD View Post
    Keep chugging at it mike....We are all in this together. The guys that know or claim to know how it works ain't telling their secrets.
  12. #32
    Try putting your Minimum VSS to 0.
    Engine>Idle>General - Minimum VSS is 2 stock. Change to 0.
    Go from there.
    Total Masshole.
  13. #33
    Sep 2008
    1,668
    Trying that now.
  14. #34
    I haven't had much luck with it yet either. Kinda gave up until we can log mapped points but appears to be some kind of clip being missed that's keeping it from working. Also I'd like to know supposed park position of the cams to better figure out over lap
  15. #35
    Sep 2008
    1,668
    That didn't work either.
  16. #36
    Sep 2008
    1,668
    How do I control which mapped points are used when? Is that what the distance tables do? What do the numbers in the distance tables mean?
  17. #37
    I have the intake cam specs for the trucks if anyone wants it.
  18. #38
    Quote Originally Posted by 02reaper View Post
    Post em up
  19. #39
    Sep 2008
    1,668
    I got it!!!
    Driveability is a little off now...I'm sure once I can datalog, I'll be able to make the thing nice again and still have bump. I still don't understand how to tell it what mapped points I want it to run from, but I've been able to give the owner of the car the idle he wants.
    Try 5.hpt
  20. #40
    Quote Originally Posted by Matt@MMP View Post
    Post em up
    F150 5.0 Intake cams
    SMOOTH4W: CAM ANALYSIS PROGRAM (REV. 1.0.0.50)
    October 31, 2013 - 16:49:10
    OVERALL EVENT:
    133.41° @ 0.200
    150.59° @ 0.150
    168.12° @ 0.100
    189.29° @ 0.050
    209.94° @ 0.020
    225.21° @ 0.010
    253.52° @ 0.004
    NUMBER OF SMOOTHING PASSES = 5
    YMAX = 0.416832
    ACC(0) = -0.000406
    RBAS = 0.8069
    RF = 0.3750
    OUTPUT OPENING SIDE
    AMAX = 0.000770 @ 53.0°
    AMIN = -0.000441 @ 3.0°
    VMAX = 0.011379 @ 38.0°
    JMAX = 0.000152 @ 58.0°
    JMIN = -0.000096 @ 44.0°
    +RCMIN = 0.463 @ 3.0°
    -RCMIN = -1.602 @ 54.0°
    AREA (TOTAL) = 13.484
    DESPT1 = 33.76° @ 0.2000
    DESPT2 = 38.18° @ 0.1500
    DESPT3 = 42.65° @ 0.1000
    DESPT4 = 47.87° @ 0.0500
    DESPT5 = 52.68° @ 0.0200
    DESPT6 = 55.73° @ 0.0100
    DESPT7 = 60.99° @ 0.0040
    MAX P.A. = 26.22 @ 40.0°
    EVENT = 76°
    P-FILENAME: BL3E-6A271-EA-1.S01
    OUTPUT CLOSING SIDE
    0.000738 @ 46.0°
    -0.000459 @ 5.0°
    -0.012048 @ 36.0°
    0.000106 @ 41.0°
    -0.000093 @ 56.0°
    0.447 @ 5.0°
    -1.934 @ 51.0°
    13.247
    32.94° @ 0.2000
    37.11° @ 0.1500
    41.41° @ 0.1000
    46.77° @ 0.0500
    52.29° @ 0.0200
    56.87° @ 0.0100
    65.77° @ 0.0040
    27.37 @ 38.0°
    81°
