injectors have my head hurting been trying to get my car to idle for 2 days
Hello guys I feel like im going in circles just trying to input injector data. I have the data but have no idea how to input anything other than the flow rate and the minimum PW. Ive searched and searched and have gotten nothing but a head ache lol.
the car is a 2000 camaro
5.3 bored to 3.905 wiseco pistons callies rods
ms4 cam
vic jr intake
accufab 4150
42lb injectors
th400 trans
no ac no ps
doing a speed density tune obviously no MAF with the 4150.
any info will help even if you tell me to go read more as long you tell me where haha.
Ok. I will be giving it a try when I get off work. Also my car is throwing a p0180 for the map sensor it reads 89 kpa at idle (as much of an idle as I can get anyway lol.
I would say your map reading is very high. I have a 2004 5.3 with a 212/218 cam, truck 8.1 injectors, cai and 1 3/4 lt headers and my map at idle is 39 kpa. Your reading is more like a wot reading. My wot is 97 kpa
With a vacuum leak that bad you should hear a huge sucking sound near where the leak is located. Spray some
MAF cleaner or other solvent-based cleaner spray around the intake manifold and your motor will speed up when
you spray it close to where the vacuum leak is located. Maybe the throttle body is not connected to the intake
manifold properly, or maybe a vacuum hose is disconnected. Are there any noises or other strange behavior?
The MAP you are seeing indicates you have hardly any vacuum at idle. Does the MAP fluctuate wildly or is it
steady?
