Results 1 to 5 of 5
Thread: VCT Optimum Power enable pedal Position % Limit reached?
    Under Engine>Airflow>VCT>Optimum Power>Enable Pedal Position
    The Max Value on this Tune I can Get is 4% and stock was 30%. Just a small bug I am sure as it feels as though the change took effect just didn't show it. Thanks! This is on Another 14 5.0
    Tuner in Training bravo685's Avatar
    Feb 2014
    South FL.
    14
    Quote Originally Posted by RickClarke23 View Post
    The value is in percent and should be used as a decimal value.
    4% = 0.04
    30% = 0.3
    No I have other files that read correctly but once you change them they won't go back.
    Oct 2007
    Crawfordville, FL
    2,412
    I just corrected it, so download the latest 2.25 and you will be able to adjust it.
    Eric Brooks
    HP Tuners, LLC
    Thanks Eric.
