Results 1 to 11 of 11
Thread: Beta and Public release?
    Aug 2004
    Franklin,OH
    215
    Is there a way to install these so that both versions stay active and dont overwrite one another? Trying to avoid installing each one every time I need to use it.
    Mar 2014
    McAllen,TX
    160
    That's a great question hopefully they have a solution for this
    Josh Performance Tuning (956)784-0059
    https://www.facebook.com/joshperformancetuning
    Feb 2006
    South Carolina
    1,525
    There is a way that involves moving one folder to a new location prior to the install. I have done it, but I can't recall the exact sequence to write it out for you.
    Jaime
    Aug 2004
    Franklin,OH
    215
    I tried making a new HP Tuners Beta file and installing there but it still overwrites on install.
    Sep 2002
    Chicago, IL
    6,395
    You must be running a very old version of the public release.
    2.24 and 2.25 can be installed at the same time with no issues.
    We got this guy Not Sure, ...
    Advanced Tuner Witt's Avatar
    Aug 2006
    Pittsburgh, PA
    380
    I've had no luck with today's version of 2.24 and 2.25.
    The beta overwrites 2.24 and trying to reinstall 2.24, the installer tells me to uninstall the newer version (2.25) then closes.
    Edit: Windows 8.1 if it matters.
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by Witt View Post
    This is the result I was having, as well.
    Jaime
    Dec 2009
    1,084
    Same result here.
    I also even created a new user account (called beta) logged off current acount and intsalled Beta came back to current account and it was over written.
    Sep 2002
    Chicago, IL
    6,395
    I just put up a new beta that fixes this issue.
    Aug 2004
    Franklin,OH
    215
    Works great. Thanks.
    Tuner in Training bravo685's Avatar
    Feb 2014
    South FL.
    14
    I'm not able to uninstall the current beta (downloaded 4/9/14 9PM EST).
    Using Add/Remove Programs only removes the name listed in Add/Remove. The application folder and executable are still in C:\Program Files(x86)\HP Tuners\. If I try to install 2.24 I get a newer version already exists and the installer exits. Re-installing the beta will return the application name in the Add/Remove Programs.
    Using Win7 pro 64bit
    Rob
