Have a weird issue... '14 GT, was originally on SCT, flashing fine... then started failing repeatedly today (would fail to flash), tried like 8 times... restore to stock, then reflash. Restore to stock always takes, writing custom tune would fail. WTF. Finally got fed up and unmarried the SCT device.
Took like an hour or so to move my calibration over to HPT using the beta... go outside, flash car, no problem, takes the tune. Drive it around, seems some of the fuel strategies are missing compared to SCT as idle is now like at a -30% fuel trim and cold warm up was really hesitant (car is on 60# injectors & E85), didn't have this issue with the SCT map (mostly 1:1 copy as the tables are identical). Figured w/e, car ran fine warmed up. So start doing some fuel tweaks to idle (transient and maf curve). I was able to flash the car 2-3 more times... then go to flash again... progress gets to 74.2%, pauses (which it would pause intermittently at 74.2% or so every time), but this time it just blasts straight to 100%, during the pause the HPT device was showing the LED go off for a bit, then back on... so some kind of communication error? In any case, no go, car doesn't start anymore. Weird. Tried a few more flashes with HPT... each one fails. At the same 74.2% marker.
Ugh... guess I'll try flashing the unmodified HPT map I pulled off the ecu later.
