Page 6 of 14 FirstFirst ... 2345678910 ... LastLast
Results 101 to 120 of 263
Thread: HP Tuners 2.25 BETA Release (2011+ Mustang supported + others)
  1. #101
    Oct 2007
    Crawfordville, FL
    2,412
    Quote Originally Posted by pacoflyer View Post
    Does HP tuners plan on adding the Focus ST into the mix? Our current options are Cobb Access port and SCT. With a bolt on turbo we have Focus ST in the 380-400 whp and wtq, so this platform has much more to give and more options would be great!
    Yes, but it will probably not be this year.
    Eric Brooks
    HP Tuners, LLC
  2. #102
    Oct 2007
    Crawfordville, FL
    2,412
    Quote Originally Posted by MikeOD View Post
    Do we need to be worried about bricking computers? Does the bootloader portion of the Copperhead get erased/rewritten every time like say an LS1B, or is it safer when writing entire, like say an E38 or E67?
    No need to worry.
    Eric Brooks
    HP Tuners, LLC
  3. #103
    Oct 2007
    Crawfordville, FL
    2,412
    Is it possible to add the min/max values to the editor like we have in 2.24 and older?
    You mean display them so you can see what they are set to?
    Eric Brooks
    HP Tuners, LLC
  4. #104
    Sep 2008
    1,668
    Yeah, in 2.24 and older...although I never tuned any Fords with it, with any GM stuff, when I mouse over a button to open a table, or a box to enter a constant, the info at the bottom of the editor window gives the explanation of the function, as well as what the min/max values you can enter in. Like for example, on my 2010 Camaro SS / E38, if I mouse over the Injector Flow Rate vs. Pressure table, the bottom of the window shows me that I can enter anywhere between 0 and 127 lb/hr...so I know if I were to need larger injectors, I'd have to start scaling airmass tables and so on. I don't see that info anywhere in the 2.25 beta.
    2010 Camaro SS M6. Stock Bottom End, Heads/Cam/Intake/Headers/Exhaust.
    2005 Silverado RCSB. Forged 370 LQ9/Borg-Forced Inductions T6 S484/Jake's Stage 4 4L80E with D3 Brake/4WD.
    2023 Durango Hellcat
  5. #105
    Sep 2008
    1,668
    Just noticed that the newest build of 2.25 can flash my Chevy now
  6. #106
    Progress on this is awesome, any eta on the scanner?
  7. #107
    Oct 2007
    Crawfordville, FL
    2,412
    Quote Originally Posted by xrelapse13 View Post
    I'm working on getting some scanner functionality added to 2.24. 2.25 scanner is still being developed.
    Eric Brooks
    HP Tuners, LLC
  8. #108
    Nov 2009
    All Around
    3,149
    for the first time I used HP last night, tuned 3 cars in the time in takes to tune 1 and I must say, GREAT JOB ERIC!!!
  9. #109
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    Quote Originally Posted by SultanHassanMasTuning View Post
  10. #110
    May 2008
    5
    I see you say 2005-up Mustangs, are the 05-10 V6 Mustangs included in this?
  11. #111
    HP Tuners Support
    (foff667)
    28,268
    05-10 V6 mustangs are supported in 2.24, no beta necessary.
  12. #112
    Nov 2009
    All Around
    3,149
    Eric,
    tuning with HP tuners and logging with SCT logging knock stays at zero and doesnt move which is weird. also were you able to increase and create knock maximum load?
  13. #113
    Oct 2007
    Crawfordville, FL
    2,412
    Eric,
    Email support if there is something you cannot edit properly.
    Eric Brooks
    HP Tuners, LLC
  14. #114
    Nov 2009
    All Around
    3,149
    max load for knock learn table is missing
  15. #115
    Oct 2007
    Crawfordville, FL
    2,412
    I will get it added ASAP.
    Eric Brooks
    HP Tuners, LLC
  16. #116
    any support for 2000 v6 stang yet ?
  17. #117
    HP Tuners Support
    (foff667)
    28,268
    Quote Originally Posted by dsmlights View Post
    Unless we first invent an eric cloning machine I don't forsee this happening in 2014.
  18. #118
    Advanced Tuner Montecarlodrag's Avatar
    Nov 2009
    Pegasus Galaxy
    919
    You must have at least 5 clones of him, because more Ford development happened in the last year than the previous 5 combined.
    9 sec Montecarlo SS
  19. #119
    Apr 2008
    4
    I currently have the Ford Racing ProCal loaded on my 2012 GT. Do you know if I will be able to read or reflash with the tuner? Thanks.
  20. #120
    Oct 2007
    Crawfordville, FL
    2,412
    Quote Originally Posted by TheViking View Post
    You will be able to read the tune. You might need to send the read to us for me to create the definition though, I am not sure if I have the definition for the FRPP file done yet. Once that is done you would be able to license and edit the file.
    Eric Brooks
    HP Tuners, LLC
