Will HPTuners have the ability to use or create value files(or something similar)?
Every time I start a new tune, I start with my Roush strategy and have to change the tables for my injectors, fuel system, gears, tires, and turn on knock sensors. It would be much easier to make a value file and click add and it's loaded. I have been doing the compare and copy as that's the only way to do it, that I know of.
How do you save tables?
Are you using the "Comparison Log?" It lists all of the differences between files in a list type format and you can right click on a header like "Injectors" and "Copy Differences" and it copies all the differences under "Injectors" in one step. It is found under "Compare">"View Comparison Log"
As for saving a table, when you have a table view open, spark advance for example, there is a little disk icon in the upper left corner that allows you to save just that table from a tune to be used later or maybe sent to someone via e-mail.
Edit: The table save function is currently only available in 2.24.
Jaime
One thing you can do as a work around is to add all the various parameters you want to copy over into Favorites, then you open the file you want the values from, go to favorites and copy over whatever is different.
The new import/export changes system will make all this simple.
Eric Brooks
HP Tuners, LLC
Any chance a 2014 Ford Flex will be supported? I've got one that is the regular NA v6 that seems to have very aggressive torque management.
228R 114LSA cam, PRC stage 2.5 5.3 milled heads - 11:1CR. FAST90/NW92, FTP 98mm lid, ARH headers, 3200 stall, 3.73 gear,
auburn racers diff, strano springs, koni sa shocks, 35mm/22mm sway bars, LCA relocation brackets, adj panhard/LCAs, subframe connectors, STB, R888 tires
Can I use this release to tune a custom 5.0L installed in a hot rod with the Ford Racing Control Pack for 5.0L.
http://www.fordracingparts.com/parts...KeyField=12284
Any eta on enabling the tow/haul mode on the 2014 trucks? I can send over a stock file if needed.
Hello! I apologize for the language, write with the help of an interpreter Google. Where can I download the beta version 2.25?
Can I please get the download link for the 2.25 beta?
