Page 11 of 14 FirstFirst ... 7891011121314 LastLast
Results 201 to 220 of 263
Thread: HP Tuners 2.25 BETA Release (2011+ Mustang supported + others)
  1. #201
    Nov 2007
    232
    What happened to the desired idle rpm and the adders vs ect? Just downloaded an update at about 4pm cst yesterday and they aren't there. Version is 2.25.831 if that helps. Just nabbed 2.25.833 just a few min ago...still not there.
    "I didn't fail, I just found 100 ways to do it wrong." - Benjamin Franklin
  2. #202
    Sep 2002
    Chicago, IL
    6,394
    They may have moved around a bit. If you're sure you can't find them, please send in your file to support.
    We got this guy Not Sure, ...
  3. #203
    Nov 2007
    232
    I checked through every table. Where they should be under the idle...not there. I don't think it has anything to do with my personal tune as they aren't around on anything I've got. I've got stock files from boss, cj, gt500 as well as some other members tunes...those tables are nowhere to be found. File has been sent
  4. #204
    What's the update on 2.25??
  5. #205
    Nov 2007
    232
    2.25.835...still no idle adjustments
  6. #206
    Sep 2008
    1,668
    Hi, do you plan on supporting the Focus? I have a friend with a 2013 Focus ST.
    2010 Camaro SS M6. Stock Bottom End, Heads/Cam/Intake/Headers/Exhaust.
    2005 Silverado RCSB. Forged 370 LQ9/Borg-Forced Inductions T6 S484/Jake's Stage 4 4L80E with D3 Brake/4WD.
    2023 Durango Hellcat
  7. #207
    Advanced Tuner Witt's Avatar
    Aug 2006
    Pittsburgh, PA
    380
    Quote Originally Posted by schaid View Post
    2.25.841
    I'm showing them under the idle --> rpm tab.
  8. #208
    Oct 2007
    Crawfordville, FL
    2,409
    Quote Originally Posted by MikeOD View Post
    Yes, it is being worked on.
    Eric Brooks
    HP Tuners, LLC
  9. #209
    Sep 2008
    1,668
    Awesome!!!
  10. #210
    Nov 2007
    232
    Bill sent me an email as soon as it was all working again.
  11. #211
    Sep 2009
    19
    I sent an email requesting for the full version, and was told it would appear on customer's page. The only one that appears is 2.24.830, which I already have, I still downloaded it and yet I still seem to have limited access to the ford f series, im trying to tune a 2009 Ford f-150 4.6, but cant remove all torque management nor other common tabs appear like rev shift points or shift pressure, cuz it appears the same as the demo version. Any help plz??
  12. #212
    Oct 2007
    Crawfordville, FL
    2,409
    Quote Originally Posted by arnoldocadena View Post
    We are currently developing support for the TCM in the 09/10 F-150, that is why those parameters do not appear.
    Eric Brooks
    HP Tuners, LLC
  13. #213
    Sep 2009
    19
    oh ok, I understand, but another thing is that when I tried to open a 2011 f-150 file from a member that posted it here to see, I cant open it. it tells me "This file was created with a newer version of software. Please update your software to the latest version."
    And also I see others posting they have the 2.25.835 or the 2.25.841, mine is still says 2.24.830.?????
  14. #214
    Oct 2007
    Crawfordville, FL
    2,409
    Email support in you need aces to the beta version.
    Eric Brooks
    HP Tuners, LLC
  15. #215
    Sep 2009
    19
    Ok, i will do that. Thanks.
  16. #216
    Im getting a error w a 2013 mustang gt that says ignition cycle times out. I have disconnect the battery, nothing. Disconnected all of the following, boostaspark, gauges, remote start, and everything else I can think that would cause the ignition not to show cycling. Even reflashed back to stock w my sct software. This is the first time im trying to do a read. Never had this issue w sct. I only have the version that camew the software which is 2.24. Why must you request the latest software? Shouldn't it be readily available for new customers? Thats the only thing I can think is the issue. Vcm shows my car as a 2010 mustang up to the point of the ignition cycle too. Definitely aggravating.
  17. #217
    Aug 2006
    Pittsburgh, PA
    380
    Quote Originally Posted by kaineoutlaw View Post
    Check thread title....2.25 is needed for 2011+
    The version (2.25) that supports copperhead PCMs is still in beta as new features are being added near daily.
  18. #218
    Aug 2006
    Pittsburgh, PA
    380
    Kinda curious if there's been any progress on the flex fuel side of things. I know you've been ultra busy on scanner and 2015 work, I'll be holding out for true Coyote flex fuel support until I'm dead though.
  19. #219
    Oct 2007
    Crawfordville, FL
    2,409
    Quote Originally Posted by Witt View Post
    I'll get it added after the 15 support is done.
    Eric Brooks
    HP Tuners, LLC
  20. #220
    Where is the EECV support at currently? I have a cobra that has MAJOR issues and would like to make some changes. Since I am not going to buy SCT's tuning software, this handheld is worthless...
