2001 TA. Just installed edelbock ported by lingenfelter heads, comp cams 230/234 600/601 cam, comp cams gold rockers, 3000 stall converter, headers, magnaflow exhaust. Downloaded repository tune, broke in the cam, adjusted idle. Everything seemed fine. Drove from Gainesville, Florida to Sebring Florida for work. No problems. Started tuning the ve and maf and developed a backfire. It started out just at idle and seemed to have no effect on acceleration. Over a period of an hour or so it seemed to backfire more and more at idle and acceleration did not feel as smooth. Pulled it in to the garage and noticed a small fuel leak at quick connect to fuel rail. Put on new quick connect, road tested, still backfiring. Did a smoke test, no leaks. New to tuning and unable to read the scan log well enough to determine problem. Any suggestions? I haven't pulled valve covers yet. Not hearing any valvetrain noise but I did use comp cams pushrod length checker to order correct pushrods and have not double checked clearance and torque since initial install.
