Had a chance to work on a supercharged A4 LS1 GTO today.
Didn't have a wideband so I couldn't make too many changes, take a look at the before and after.
Here's what I changed so far(coming from a stock "canned" supercharger tune)
-Removed timing as the intake temps increase
-Removed timing at the edges of the timing tables
-High and low octane tables now have a safety margin between them
-Smoothed out part of the VE table
-Very small change to the PE table
-Changed the PE enable to prevent PE from coming on too soon at low rpms
-Added some torque management back in between shifts
-Disabled rear O2 sensor codes
-Speed limiter removed
-Other minor changes
Here's what still needs to be done (most of this will have to wait until after the WB is installed)
-Change the injector data to be correct for Ford green tops (42lb/hr @ 44 psi, vehicle is at ~60)
-VE table tuned
-MAF curve tuned
-PE table corrected for proper VE and MAF data
-Needs all new transmission table data
Posting this because someone wanted to see the changes, however I'm always open to feedback.
-Files Below-
