Results 1 to 3 of 3
Thread: 1998 Chevy Truck - Disable Passlock/VATS?
    I hate to make a new thread as there are hundreds asking the same thing but different vehicles and different answers.
    I have a 1998 Chevy truck with the Vortec 5.7
    I guess it's anti-theft system is the Passlock or Passkey that will kill the engine 1 second after starting unless you do the re-learn procedure. (Key on for 15 minutes, off, key on for 15 minutes, etc)
    I want to get rid of this. Do i just change VATS to "Disable" under system or do I need to do anything else with the theft related DTC's? At the same time I don't want the security light staring me in the face.
    Thanks!
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    Just change the VATS to disable will allow the engine to stay running with a VATS issue. But the security light will still come on. You will need to diagnose the VATS system.
    Russ Kemp
    Quote Originally Posted by Russ K View Post
    That's kind of what I figured. I was more worried about getting stuck somewhere because the truck won't stay running. I had the battery disconnected for a few days while I was working on it, put it all back together and that's how I learned about the passlock setup.
    So I assume everything with the security system is still working normal behind the scenes, disabling VATS just keeps it from killing the engine.
