Results 1 to 3 of 3
Thread: invalid cable id
    Mar 2014
    1
    invalid cable id
    im getiing this pop up it says
    invalid cable id
    you do not have license support for this interface.
    Dec 2009
    1,084
    email support at hptuners.com
    Mar 2012
    38
    I had similar issues today. Sometimes it also complained that it cannot locate VCM and so on. I saw it few times before and it always solved disconnection/connecting
    cables. Not today. I investigated whole interface, opened it, checked soldering of connectors, everything was fine. Then I realized, that the DSUB-15 connector is very
    loose. It was always, but now it barely holded in place when not screwed. I found that the two nuts, holding connector in panel, and serving as nut for cable screws are
    too long and that they are preventing the cable connector to sit as deep as possible. I removed them, connected cable, that was 1-2mm deeper than before and voila,
    interface was back alive! Hopefully this helps to someone with similar issue.
