Results 1 to 10 of 10
Thread: 2001 silverado 0411 3bar os not avalible
    Apr 2013
    11
    2001 silverado 0411 3bar os not avalible. Can someone please help I have searched and got too many results.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    likely using an operating system that didn't have enough room for 3 bar, there weren't many but there were a few.
    Apr 2013
    11
    12208322 i have already licensed it. what are my options?
    Apr 2013
    11
    can i flash a different os? how many more credits will it cost? can i send my tune to you and you make it 3 bar compatible?
    HP Tuners Support
    (foff667)
    28,268
    Most use the 12212156 operating system for these 411 swaps.
    Apr 2013
    11
    bill how do i put 12212156 on it? will it cost me credits?
    Advanced Tuner 68Camaro's Avatar
    Mar 2011
    Van Buren, AR
    326
    12212156 is a 02 Camaro OS. If you have already tuned one of those then you can just use the file you already have and do a Write Entire and it will erase your PCM and then write the new OS to your PCM. If you do not already have this tune file then you can find one in the tune repository (hopefully, but I'm pretty sure one is out there) and download and use it - unfortunately you will have to spend 2 credits to license said file and then spend another 2 credits for the 3 bar OS. Another $200 in the overall scheme of building a fast car isn't the end of the world tho. Hope this helps and good luck with your project!
    HP Tuners Support
    (foff667)
    28,268
    it was also used in 2002 Silverado, sierra, firebird and I'm sure a few other applications. Because it was used in so many different types of applications its a very flexible operating system in the eyes of most people doing pcm swaps, etc. 123killagum I don't know your situation if you are running some sort of engine/pcm swap application but because you put 0411 in your title I can only assume you are as virtually nobody specifies the service number of their pcm unless thats what they've done.
    Advanced Tuner Shrek's Avatar
    Nov 2011
    753
    Quote Originally Posted by 123killagum View Post
    This is a bit of a "look before you leap" scenario. You could have read the tune (without licensing it), and checked what OS options were available.
    You are running 2001 OS12208322 - which does not have a 3 Bar option. However, 2001 OS 12202088 does have a 3 Bar option.
    OS12208322 was an OEM update for OS12202088 - most 2001 trucks received this updated OS, while 2001 Camaros did not.
    Apr 2013
    11
    is it possible to flash this 12202088 or 12212156 via tech2 and still be licensed? is one better than the other? thanks for all the info. im turboing my 5.3 swaped 73 c10. just trying to give as much info as possible. again thank you guys so much.
