Results 1 to 3 of 3
Thread: Commanded AFR/ AFR error setup(Please HELP! I have lost hair over this)! lol
    I can no find a straight answer on this. I have searched here, Google, and dug all over the internet. I just can't find all of it. This seems to easy to be this hard!
    So basically, how the heck do I setup COMMANDED AFR and AFR ERROR.
    If someone knows where I can find this, send me the link. Anything helps guys. Thanks so much!
    Feb 2006
    Canada
    1,957
    Since your in the Enhanced EIO section here I will assume your working with a wideband. Now, forget the AFR stuff, it's old news. You need to wrap your head around working in Lambda from this point forward. Since your new to this, right now is the time to get off on the right foot here! This link will show you how to set your config up properly for wideband tuning of your PCM.
    http://www.performancetrucks.net/for...lambda-524099/
    And this link will show you the conversion of AFR to Lambda. Use this chart as a reference until you get a good feel for what Lambda your aiming for when in PE mode with different types of induction systems. Be it N/A, FI, or Nitrous. You'll always aim for Lambda 1 no matter what fuel you are tuning, then you choose your PE Lambda value and use your new cfg to get your target.
    http://www.wallaceracing.com/air-fuel-lambda.php
    **and a side note for you, Wallace Racing has a couple of really interesting calculators on their site that may be to your liking as well. Poke around there a bit to see what they have!
    2000 Trans Am WS6
    Got it figured out! THANKS!!!
