Results 1 to 6 of 6
Thread: TBSS 403 Tuning Help.
    Mar 2014
    4
    Guy's Sorry to be a newb here but i am running out of options I live in Central IL and been trying to do the best i can on figuring out how to tune my TBSS but seems nothing is helping its just to far over my head.
    I did not know if i put the tune up here with my mod list if some of you guys could take a look at it and tell me what you think?
    Brien
    13,564
    After you post the file and perhaps some scans post the full mod lists and ANYTHING that the vehicle is doing.
    You have to help us help you to try and maybe figure stuff out.
    But in the mean time, take some personal time to read up on tuning and get yourself a better understanding of what is going on. Read other threads and try to gain knowledge or else this thread will likely just sink to the abyss.
    Mar 2014
    4
    Thanks 5FDP it's a struggle for me on this i will say that much. I would love to find a place to go take a class on this.
    13,564
    I'll admit I don't know alot either, I learn new things everyday. But from just lots of reading and browsing and some trial and error I get a better understanding.
    They do make some books on general infomation stuff, greg banish has made a few.
    Mar 2014
    4
    Mods:
    403 LS2
    FAST LSX-RT TRUCK 102MM INTAKE MANIFOLD
    Trick flow "As Cast" 220cc LS heads
    Yella Terra Ultralite Shaft Mount Roller Rockers 1.7
    Nick Williams 102MM DBW TB
    Wiseco -3.2cc Flat-Top Forged Piston Set for 3.622" Stroke
    Eagle Rod 6.125" Non offset LS1 rod set
    LS2 Car injectors 56# at 4bar
    Fast fuel rails
    LS7 Maf & Bung
    OBX Header / Offroad Y
    Yank 3600
    Built Trans
    here are the cam specs:
    BULLET RACING CAMS
    INTAKE EXHAUST
    DURATION AT .050 227 235
    LOBE LIFT .3677 .3655
    SEPARATION 115. -OP-CL OP-CL
    TIMING EVENTS .050 2.5 44.5 56.5 -1.5
    DURATION AT .006 281 292
    GROSS VALVE LIFT .625 .621
    VALVE LASH (HOT) .000 .000
    DEGREE INTAKE LOBE TO 111
    Brien
    Mar 2014
    4
    guys sry the cam specs i had set up so u could read it better for some reason it took all the spaces out sry.
