Results 1 to 6 of 6
Thread: PE settings for FI
    PE settings for FI
    After setting my target ratio (currently 11.4:1), when should I have it kick in? The shop that gave me my "start up" tune has it kicking in at 87 kPa with 2% throttle opening enable. The current issue is that in high gear with low load (highway) the PE will kick in any time I give it just a little bit more throttle (slight incline) because I will go above 87kPa. I currently end up downshifting just to go up small inclines so that I don't just keep dumping fuel. The shop said these are typical settings. I feel that I should either have the throttle enable higher, or go to 100% throttle enable. Is that about right? And at what throttle % should I be aiming to kick in at?
    2012 Camaro SS/RS M6. TVS2300 w/rear OD cog drive and ported lower manifold, On top of a forged 416.
    1999 GMC Sierra 2500. Stock 6.0L, LT headers, cat delete, and Airaid intake.
    1965 Oldmobile Cutlass. 5.7L LS1/4L60E transplant in progress from 98 TransAm donor car.
    Nov 2009
    All Around
    3,149
    depending if you have upgraded your OS, on FI you can set it to start 95kpa and 25% throttle would be very safe
    Thanks. I haven't upgraded my OS, just the standard E38 stuff. I do have the 3 bar MAP to log boost though, and a wideband in the car. By 25% throttle, do you mean actual, or the reading the TPS gives? At idle my TPS reads about 12-15%, and WOT is 84%, setting the enable to 25% would enable it at about 10-15% actual throttle, correct?
    Jun 2007
    1,100
    I always set PE enable at about 5-10 kpa above highway cruise reading, and at about 10% above idle throttle, and I set rat to 2, and delay to 10 crank pulses. (I like throttle response. )
    Thanks for the input. I haven't looked too much into the throttle settings yet. I think that might be what I try next once I get the PE set correctly. Baby steps.... I'll be happy to just get it to stop running so rich, going into PE just cruising in 6th is killing my mileage.
    Quote Originally Posted by SultanHassanMasTuning View Post
    Why do you say if I upgraded my OS? Since I haven't, should I set it to something other than what you recommended?
