Results 1 to 11 of 11
Thread: DTC's during WOT question
    Advanced Tuner HartRod's Avatar
    Dec 2006
    Pensacola, FL
    489
    Background:
    6.2/6L80/TVS1900 (7lbs of boost, so far)
    ZR1 Map sensor
    CompCam 219/235 113 LSA (with dual valve springs)
    LS3 MAF
    04+ Corvette Pedal
    I'm getting the following codes when I do a WOT run:
    P0106 MAP system peformance (pending) (immature)
    P0121 Throttle position circuit insufficient activity (immature)
    P1101 Mass air flow sensor out of test range (pending) (immature)
    The truck runs fine. I can clear the DTCs and they won't pop up again unless I do a WOT run. Thoughts or suggestions. I'll post the tune and log later.
    69 Suburban Bagged & Blown: http://67-72chevytrucks.com/vboard/s...d.php?t=200387
    68 Farm Truck build thread-LS3/6L80/TVS1900: http://67-72chevytrucks.com/vboard/s...d.php?t=358692
    Feb 2006
    Canada
    1,958
    Is your VE tuned properly in PE mode? You may be "out of range" between the VE tune and the MAF tune causing this.... just a guess without the tune and log of it happening. Usually the P0121 is set when the idle is too low or timing is too low with the addition of a cam. But since it is only at WOT, I would look to the tune between the VE and MAF first. If you keep getting the P0121 then I would either increase the idle or increase the idle timing to get your MAP out of the P0121 range
    2000 Trans Am WS6
    Dec 2006
    Pensacola, FL
    489
    Here's the tune. I can't get the log to load because the file is to large.
    Jan 2008
    242
    Under Diagnostic Tests PO101,PO106,PO121 change MIN ECT to 493 and Max ECT to -40
    Feb 2006
    Canada
    1,958
    Yes, that will delete the test if you cannot get your MAP outside the P0121 range. I just would not jump straight to it if it's possible to keep it active.
    2000 Trans Am WS6
    Dec 2006
    Pensacola, FL
    489
    Quote Originally Posted by C5 2000 View Post
    Thanks.
    Quote Originally Posted by MMGT1 View Post
    And I agree, I would prefer not to disable it until I am sure that there is an issue. This is a retrofit, so I'm kinda winging some of it, LOL. Is there a way to reduce the size of the log file after you run it? I guess what I'm asking is, can you cut some of it out so the file is smaller?
    Advanced Tuner gn2beatu's Avatar
    Sep 2011
    Germantown WI
    414
    I couldnt load the tune now, but also dont forget to max ALL the tables under Engine Diagnostics, General, P0068.
    This will keep the limp mode problem from happening when you up the boost. If you dont raise these, you will be flowing more air than the computer will want to see for a given TPS/MAP/RPM.
    2000 Regal GS ~ 3.25 Pulley ~ Headers ~ 3"ex ~ 1.85 Rockers
    Sold 06 TBSS ~ Front Mount T88 ~ 0-30 in 1.17 ~ 0-60 in 3.0
    Wanted ~ Engine-less 95/Older 4x4 ~ Jeep/S-10/Ranger for TT Project
    Dec 2006
    Pensacola, FL
    489
    Quote Originally Posted by gn2beatu View Post
    Did you take a look at my tune? Thanks,
    Is there a way to adjust these ranges to make the computer happy with SD vs MAF vs TPS diagnostics and not disable the tests? They must be different on OE supercharged vehicles. Has anyone requested the tables from HPtuners for any OS? I am pretty sure I am having some of these same issues. I have a nearly perfect VE table and MAF curve but once in dynamic air calc mode the ECM isn't happy with something as soon as pressure is above atmospheric.
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    Quote Originally Posted by griffincox View Post
    Is there a way to adjust these ranges to make the computer happy with SD vs MAF vs TPS diagnostics and not disable the tests? They must be different on OE supercharged vehicles. Has anyone requested the tables from HPtuners for any OS? I am pretty sure I am having some of these same issues. NI have a nearly perfect VE table and MAF curve but once in dynamic air calc mode the ECM isn't happy with something as soon as pressure is above atmospheric.
    Disable as advised above and perform a wide open throttle pull from stop to redline. Log the regular PIDs including MAP, RPM, MAF and Dynamic Airflow (for SD tunes). At the ETC Throttle test (P0068) rpm breakpoints, note the airflow value and add 10%. Put this value in the tune cell. Do this for all axis points. Do the same for the Airflow delta (interpolate), MAP delta and IGN.
    Re-enable and see if REP goes away.
    Ed M
    [email protected]
    Quote Originally Posted by mowton View Post
    Ed M
    I have pretty much done that, not quite as specific (probably should make them more accurate, as right now they are overly high limits) but my issues is not with P0068, its with P0121. As far as I can tell the enable/disable temps are the only adjustable parameters for P0101, P0106, and P0121 in this section of the HPtuners interface. Is there tables available (in any OS, for proof of concept) that allow modification to the airflow values for these above diagnostics?
