Results 1 to 7 of 7
Thread: 2 bar SD turbo start-up tune issues
    Mar 2014
    5
    hello,
    this is my first turbo build, and i was trying to get a start up tune so it would idle, but i am not having any luck; AFR goes very lean and it dies (greater than 17 on AEM UEGO W/B). i checked for possible vacuum leaks at the intake ports but didn't find any. Ive compared my injector data to others in the repository and mine seem pretty close with them.
    hoping someone could take a look and chime in. current tune is attached below.
    Specs:
    5.3 with "317" heads
    ls6 cam
    ls1 intake
    Siemens deka 60 #injectors
    1:1 FPR at 40 lbs of pressure
    8 an feed and 6 an return
    bosch 044 inline pump.
    76 MM turbocharger
    thanks DG.
    DG TURBO 2Bar InJ data 60.2.hpt
    Advanced Tuner c.u's Avatar
    Jun 2010
    Eville, IN
    282
    Start with the PO101,102,103 set to 0-Mill on first ERRoR. will look a the tune in a little bit.
    Mar 2014
    5
    Does it make a difference if i have them all set to 3 - No error reported? Thank You
    Jun 2010
    Eville, IN
    282
    Yes. The ECM has to see the MAF fail for SD tune only. Here are few thing you need to disable as well. With out a log,I have you set your idle up.
    Advanced Tuner gn2beatu's Avatar
    Sep 2011
    Germantown WI
    414
    Also put the correct idle value in the first cell of the MAF curve, it will still use that one to try and start til MAF fails.
    2000 Regal GS ~ 3.25 Pulley ~ Headers ~ 3"ex ~ 1.85 Rockers
    Sold 06 TBSS ~ Front Mount T88 ~ 0-30 in 1.17 ~ 0-60 in 3.0
    Wanted ~ Engine-less 95/Older 4x4 ~ Jeep/S-10/Ranger for TT Project
    Mar 2014
    5
    Sorry if i forgot to include that i have removed the MAF completely and im only running a Syclone/Typhoon IAT sensor.
    But i Appreciate the input and will hopefully get to flash this new calibration tonight.
    -DG
    Mar 2014
    5
    okay thanks, im guessing the maf DTC settings is what was affecting it, starts up great and idles a bit rich but it idles!
