Results 1 to 8 of 8
Thread: Vcm scanner pids problem?
    Sorry I'm pretty new for hptuner, I have a pro version, we tried to log pids for Ford Mustang 2007 v8, but it looks like I was unable to see or log most PIDs , I was able to see just a few of them like rpm ignition timing, throttle and just a few more.... It didn't see Knock retard and many other PiDs ... ((( so did I make anything wrong and need may be to turn on somehow missing ones? Or it's Vcm logger software problem?? Any salvation to make good logs??
    There is not Knock retard pid as many others You see eg in SCT or GM's in HPT. Visible pids should work, but SCT or GM's in HPT has them much more.
    Eastern and Central Europe American Muscle and Harley-Davidson tuning
    www.hd-customs.pl
    http://www.facebook.com/hdcustomspl
    28,272
    Knock retard is a DMA/MPID meaning it has its own specific address unique to each strategy, adding them is a huge task for ford as compared to GM, but it will get tackled this year.
    Bill please advise in VCM scanner: Table Dispay or Chart display indicates ALL PIDs are able to log? or there is some wider list of PIDs which i can add to this 2 displays?
    28,272
    table display
    So vcm scanner won't read anymore PIDs over the ones I see in the Table display, right?
    Feb 2006
    South Carolina
    1,525
    You need to right click in the table display and choose to insert PID or something like that, while connected to the car. That will pull up any available PIDs.
    The help file also walks you through it. A lot of good info there that may answer many of your questions.
    This are even more needed than knock retard (which can be calculated self):
    Desired torque (what's exact name to log in SCT?)
    Delivered torque (what's exact name to log in SCT?)
    ETC manifold vacum
    Effective area by ETC
    Wheel torque error
    Sum of IPC wheel torque error
    Actual airflow by ETC
    Airflow desired by ETC
    Without above, there's no way to tune ETC in HPT.
    www.hd-customs.pl
