please check out the ecm need some help with it to see if the problem is on the ecm , would hate to loose credits on ecm already thanks best regards
I've seen bad drive by wire throttle bodys shoot straight to 3-4 grand at start up before. Sometimes a throttle relearn fixed it other time we just replaced them.
What year is the vehicle?
look under spark section of your tune. the cat light-off timing during the first 20 seconds after starting your motor.
The PCM is being told to add 10 degrees of timing; that is what is causing your problem. I doubt a stock file has
these values in it. Do you still have the EGR in your vehicle active or did you remove this?
