Results 1 to 12 of 12
Thread: Which wideband to buy
    Apr 2013
    western mass
    142
    Hi everyone I'm looking for advice on the best wideband to buy to use with hp tuners I'm looking for something easy to use and set up to tune my personal car I don't tune for a living so I def don't need the most expensive or fanciest I see Greg banish recommended the ntk afx in one of his books but that was in 2007. And the sticky here is also a couple years old.....any ideas??? Thanks in advance Oh and I'm using it on a 95 lt1 with a 411 PCM and long tubes if it matters and should I use 2 , 1 in place of each narrow band for tuning accuracy ??? And if so do I need 2 complete kits ???
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,261
    Mar 2008
    Paris, France
    435
    Ecm afm1000
    http://www.lsxcalibration.com - Lsx Tuning France - Spécialisé Reprogrammation moteur Corvette Camaro Hummer, Ford Mustang et autres véhicules US
    Check our Facebook page http://www.facebook.com/lsxcalibration.com
    Apr 2013
    western mass
    142
    Quote Originally Posted by Brice View Post
    Ecm afm1000
    1500 for a wideband is a little excessive And all the info in that thread is old plus I keep reading all the threads and everyone has a complaint about almost every wide band out there How about that mtx-l ?? That's the most recent one in the wideband thread bill mentioned but even that post is over a year old
    13,559
    NGK AFX or AEM wideband.
    Both work fine and pretty good quality.
    AEM's wideband sensor doesnt last aslong, but should get 20-40k outta it. They just become less acurate, but not enough to matter. I run a AEM because it was only $160.
    I run the AFM1000 as well
    I have had good luck with the AFX as well.
    May 2010
    250
    The NGK AFX is discontinued. There are still plenty of them out there but if you have an issue with it, it is not supported. You are SOL. They are going to release a new model but there wasn't a time frame for it. I am going back to the FAST dual Unit I have. IT was decent, sending it to them to have it checked out first and then going to use it again.
    Apr 2013
    western mass
    142
    Ordered the innovative mtx-l. Been reading for months everywhere I read somebody is shitting on every wideband available So this was inexpensive and looked easy to use / hook up Hope I made a good choice
    Dec 2008
    on the Dyno
    1,825
    NGK AFX if you can get one. They may be not supported anymore but you can still get replacement sensors from any parts store. The next best option for under $500 IMO is the Haltech/Daytona widebands. Just as accurate as my NGK AFX. I use the AFX to mainly tune with (soon updating to an ECM unit) and I have had nothing but great luck out of it. I use the Haltech/Daytona dual channel WB on my dyno and in my racecar and it is an awesome little piece. They all have free air calibration to keep it reading accurate throughout the sensors life.
    Located in Central Kentucky
    ShorTuning
    Apr 2013
    western mass
    142
    Quote Originally Posted by LSxpwrdZ View Post
    Thank you for responding to both posts of mine which Daytona do u have I couldn't decide which was proper the lambada unit or the other and I can't seem to find much info on the differences besides cable length and one says motor cycle 0-5 volt analog output Which I was under the impression that they all were analog 0-5. Been waiting for Daytona to respond to my email On another note in the wideband sticky I did read a few decent reviews on the innovative which is why I decided to try it although I'm thinking of returning it now in favor the Daytona dual. Which I was originally leaning towards especially to get accurate bank to bank fueling info
    Dec 2008
    on the Dyno
    1,825
    I didn't get mine through Daytona and I don't even see mine on their website currently. Here is a link to the Haltech dual channel that I'm using (re-badged Daytona).
    http://www.haltech.com/product/accessories/wideband-02/
    I'm not using any gauges with mine. I'm just using each 0-5v analog output logging into HPTuners to log lambda values.
    ShorTuning
    Dec 2008
    Houston, Texas
    129
    plx m300
