Results 1 to 2 of 2
Thread: fueling question for 2.4 LE5 supercharged swap
    Quick question with regards to fueling. If i was to run MAF only for fueling for my 2.4 LE5 supercharged setup, how would I define a value other then stoich when the car gets close to 0 vacuum and +1psi on the MAP in relation to the MAF table. Is this done via LTFT MAP limits? As far as Im understanding it the car is going to still be in closed loop even when I get close to zero vac and thus I wouldnt be able to appropriately scale the MAF tables to a richer AFR as long as fuel trims were active. Any insight on how this might work?
    Tuner noorjSS's Avatar
    Dec 2011
    Albany, NY
    61
    Use the PE function, there is no point in trying to manually richen up
    2006 Chevy Cobalt SS 2.4 Turbo
    320 whp 299 wtq
