I have been following Ghost and others as they tune their 1.4T to get an idea as to how to tune the E39 ECM. They seem to be pretty similar. One sort of issue I found was when you raise the Turbo Overspeed limit Min = 2.00 you have to also raise the Turbo Failure Airmass to 2.10. This is located in the Engine>Torque Management>Turbocharger. The stock setting for these on the ATS is Overspeed=.5 and Failure=.6 Before increasing the Turbo Failure Airmass I would get a horrible rattle from the turbo which I assume is the wastegate and or BOV. BTW I set my Turbo Overspeed Limit Min to 1.5 g/cyl and the Failure Airmass to 1.6 g/cyl.
So far the tune I have feels much better than the stock and the Trifecta tune I had. Gone is the WOT kick down into a high RPM gear that just sits there and does nothing. The car pulls pretty solidly and more consistent. I need to do more data logging on it. Unfortunately the HP Tuners doesn't pickup many PIDs to log so I have to use the Trifecta to data log and then view them with the Cruze data log viewer that I found here: http://www.google.com/url?sa=t&rct=j...62578216,d.dmQ
There is still some more tuning that I want to do. I attached (hopefully) what I have so far. I also attached my stock tune. Hopefully it will provide some help for those who are learning to tune the ATS 2.0T. I wouldn't mind the veteran tuners to have a look, confirm I'm on the right path, and offer tips.
