Results 1 to 3 of 3
Thread: NGK Wideband just counts down over and over
    Tuner doubleome's Avatar
    Mar 2011
    FL
    64
    Soooooo, I have an NGK wideband and I have had it installed for a few years. I have changed the sensor a few times and have just recently changed it again. After the install everything worked as it should. But recently it will count down from 20 a few times and then read 8.8.8.8, then show my AFR and then count down a few more times. Anyone have any similar issues?
    1999 Trans Am, Automatic 60lb injectors, 255lph fuel pump, LS6 intake, P1SC Intercooled, trans cooler, polly motor/trans mounts, sway bars, subframe connectors, adj. Torque arm, Moser 12 bolt w/3.42 gears, pacetter longtubes....
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    That's either a poor power supply or poor ground.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Mar 2011
    FL
    64
    I was thinking that myself but just couldn't find it. I will look harder. Thank you!
