I loaded my closed loop tune and went for a drive this afternoon. All the DTC tests passed and trims looked ok.
I stopped at a store and stopped logging. When I came out I started the engine and started logging again. The I noticed 2 Lean codes, Bank 1+2, Immature.
If you look at the log you can see the LTFT went to 25 right off while sitting at idle. When I pulled away the LTFT dropped and never went high again.
