I've noticed that some operating systems change the injector flow rate despite the modifiers we have access to all being set to 1. Later systems seem to have a bigger variance. Why do I bring this up? Last night, I was dealing with a CTS-V that was converted to a boost referenced return fuel system. As a result, the flow rate was entered as the same value at every pressure. However, when logging, I noticed the flow rate increased as alcohol content increased (it's been converted to flex fuel with an ethanol sensor). Beyond that, the flow rate would increase greatly when going WOT on ethanol. It jumped from 98 lb/hr to 105 lb/hr, which made it lean on the ethanol. On gasoline, it didn't do this. Now... I know that the mass flow rate does indeed increase as ethanol content increases, but it seems there are modifiers that we don't have access to throwing this thing off.
Any chance some digging can be done to see what's up? I think I have a log of what's going on, so I'll try to post it this evening.
