Results 1 to 10 of 10
Thread: help boot loader issues
    Jun 2009
    hagerstown md
    23
    bootloader download request timed out... this kinda sucks...
    I keep trying to read entire and keep getting this ...
    the truck is a 03 gmc 3500 8.1 and a Allison trans.
    I have un hooked the battery and tried again
    I have hooked up a battery charger on it with the voltage @14.7
    any help is welcome I only have this truck till about 3:30
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,266
    Try reading in low speed mode.
    Jun 2009
    hagerstown md
    23
    failed this way too
    that was with out battery charger but the dash is showing 12 volts
    bill as always thank you for any help!
    HP Tuners Support
    (foff667)
    28,266
    is this during the pcm read or the tcm read when it fails?
    Jun 2009
    hagerstown md
    23
    during the vcm .... im walking away from it as its reading but its on 6% this time so far so good ... I hooked up the charger this time
    Jun 2009
    hagerstown md
    23
    still going at 28%
    HP Tuners Support
    (foff667)
    28,266
    likely just a comms issue, if it doesn't read you'll likely need to read it on a bench harness.
    Jun 2009
    hagerstown md
    23
    thank you bill this time it took!!! battery charger and slow mode !
    Feb 2006
    central michigan
    349
    that battery charger can kill your interface. it did one of mine.
    One issue I had with a vette not too long ago, I had to actually wire tie the mpvi plug to the cars odbc connector. For some reason I had a number of read problems. Once I did that and it seemed to make good contact reads and writes were no problem.
