Results 1 to 2 of 2
Thread: vin changes . need info
    Aug 2013
    dundas ontario canada
    25
    I have a 2000 sierra. The ecu is fried.
    Can I put a 2003 ecu in rewrite the vin?
    We have e test in Canada and so on so all the stuff has to match? How do I make this work?
    Feb 2009
    1,931
    2003 is a different pcm so no. You need a pcm from a 99 to 02. If you had the file from your fried pcm you can write it to the new pcm. If not you will need to get a file from the repository and write it in and then change the vin.
