Results 1 to 8 of 8
Thread: 4L60E to 4L80E in a 1998 Camaro SS
    Mar 2013
    43
    I have been searching for a week and I can't find the answers I need. I have a 1998 Camaro SS and have swapped to a 4L80e. Can I do a segment swap using the 1998 PCM? If not, what's the simplest way to get my 4L80e up and running? (repin, adapter cable, mystery black box ect..)
    Mar 2013
    43
    No one?
    Mar 2011
    384
    got a 411 pcm installed?
    My setup is a 356ci with a 260/268 (212/218 at .050 lift) duration cam with aluminium corvette heads and flat top pistons running 11.3 comp. ratio. with tuned port injection and vortec crank pick up and dizzy running a 411 pcm and 60lb bosch injectors, 1.6 ratio roller rockers. For transmission its a 4l65e built with the monster in a box mega ss kit. All in a 92 chevy ext cab 4x4 pickup with a 98 cab now installed with a third door! running only e85
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    97-98 LS1 pcm's are a non segmented so theres no way to do a segment swap.
    Advanced Tuner Montecarlodrag's Avatar
    Nov 2009
    Pegasus Galaxy
    919
    Quote Originally Posted by 99z28u_up View Post
    No
    You need to do it by other means
    9 sec Montecarlo SS
    Mar 2013
    43
    ok, can someone recommend another way?
    HP Tuners Support
    (foff667)
    28,268
    The most common way that I know of is repin for a 411 pcm, plop in the newer fbody os and have the trans segment swapped for a 4l80 one, then adjust the fuel system tables to accomodate for the differences so your fuel gauge reads correctly.
    Aug 2009
    Calibrating
    3,373
    You could just do the relay mod, works perfect with the 4L60E segment you have currently.
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
