Originally Posted by
JimMueller
Sorry if I wasn't clear earlier, hopefully this will be easier to understand... While on the dyno last week (I don't have the graph or files yet unfortunately), when the pull started at around 3000, the AFR went right to commanded (12.x) through the end of the pull. I wanted to see the torque curve earlier in the RPM's, so we began a pull at 2000RPM and ran it to 6500; on that pull, the AFR began at stoich and gradually ramped into PE fueling after a few hundred RPM instead of immediately going into PE fueling. We do not have any logs for that pull, but hopefully once I get the graph it will be easier to see. The instructor said this was a result of not having access to the PE enrichment table in later OS's.
Post #1 was referring to a street log from months ago I have with WOT pulls in it, as I was trying to see if that's how it was before. But I was minimizing table PIDs for the benefit of polling rate while tuning VE so I don't have TPS in the log. I'll have to capture new logs.
