Results 1 to 7 of 7
Thread: Upgraded to 3bar OS, flashed base map in, now ECU not readable or writeable.
    May 2009
    479
    Any ideas why? It says Authorization failure/exceeded tries/security access denied. It's also saying OS IDs don't match. Everything was working just fine until I upgraded to the 3bar OS. I was able to flash it into the car and start the car and as I attempted to make my first change, I was locked out of everything. Any ideas? Car is a 2000 WS6. Says File OS(12202088) does not match VC OS ID(1231003) Tried locking and unlocking file as well. Any ideas?
    2018 Infiniti Q60s
    2004 350z/LS2: ERL 434ci, 11.8:1,TFS245cc,262/266@113+3,Fast102,NX 102 plate,60#injectors/return w/twin 255s
    Old setup: CNC'd317s, Fast 102, 228/228@114, PT88,83#injectors/full return system. 10.84@138
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    Post the file itself. Did you make a 3 bar file from the existing stock OS in the car?
    http://www.dsxtuning.com
    Just say no to bull s***.
    May 2009
    479
    Yes it was a stock OS that was already registered to this cable. I was able to upgrade the OS and flash it once and then it locked me out after. I have to get the file as it was not done on my cable.
    2018 Infiniti Q60s
    Sep 2009
    Connecticut
    31
    Real cars don't power the front wheels, they lift em
    Apr 2006
    western NY
    339
    SO this worries me seeing this since i am going too a 2 or 3 bar setup this spring,What MAP sensor are you using?,I have been trying to figure out which 2 or 3bar i will need ,can you help?S475 on a 370 about 18 psi ,sorry to jack thread
    2000 Firebird,2002 O.S.,LQ4 370,Borg Warner S475,truck mani.,Eagle crank,Callies Compstar Rods,Wiseco-11 4.030 pistons 9.4:1 comp.,LS3CNC heads,LS3 intake,NW92mm throttle body,ID1000 injectors,BTR trunion upgrade,LJMS STG3 cam,LS7 Lifters,ARP Studs-bolts,Frozen Boost A to W intercooler,JGS 60MM BOV,2 40mmJGS Wastegates,4L80E trans wth segment swap,CircleD 3400 single disk,MOSER 12 3.31gears ,BMR K-Mem.,2 Walboro 450 pumps,Returnstyle fuelsystem MAGNAFUEL regulator.
    LS1Tech sig KRAZY K 2000 TA
    May 2009
    479
    DPE 2.5 bar custom. Works great.
    2018 Infiniti Q60s
    May 2009
    479
    The crew at HPT took care of it.
    2018 Infiniti Q60s
