Results 1 to 19 of 19
Thread: C7 Experiences...
    C7 Experiences...
    Just wondering how many have tuned near stock C7's, and what you've seen.
    I've got one to use as a test mule, and no matter what I do, it will not change HP. moved timing from 18 to 27, and no change. AFR's from low 13's to high 11's, and also no change.
    I say no change, but there are single digit swings in power. But less than 5HP, and I call it no change.
    And the WOT MAP is dropping from 97-98kpa to 91-92, so I'd say this thing needs uncorked BADLY.
    Car only has Pfadt headers. (I don't recommend them now that I've tried them)
    Nov 2009
    All Around
    3,149
    can you post a log?
    Aug 2009
    Calibrating
    3,373
    Have you modded driver demand tq?? What's your opinion on those headers? Going to buy a 2015 n I was looking at those or the American racing
    Mar 2008
    34
    Quote Originally Posted by Ben Charles View Post
    Go ARH.... Pfadt is out of business anyway
    Aug 2009
    Calibrating
    3,373
    Thanks Fran, just got my hands on an 14 truck, seeing some interesting stuff on the scanner. I'm going to drive m log for a little while before I mod it
    Oct 2009
    Nebraska
    46
    Just got done with a stock drop in air filter on C7, First one Ive got my hands on... Manual M7..
    Made 401/397 Stock on the MD1100 dyno
    Tune was 422/419.
    Im working my way through an Auto C7 today.... SLowLy
    2001 Z06 - Forged 347ci LS6, 10.8:1 SCR, TSP 233/239 113LSA, Centerforce DF 12" clutch, Rear end Brace, LPE Hardened output shaft, LPE Launch Control, Ported 243's, B&B bullets, Kooks 1 7/8 Lts, NA 446 Rwhp/406 RWTQ, Nitrous Outlet Plate Kit 725/685wtq
    2006 BOM GTO M6 - Lingenfelter Maggie 112H Package, Pedder Big Bore Kit, Rear Insert, Monster Stage 3 Clutch, SLP LMII, Kooks LTs, AIS Meth Kit, 230/236 Blower Cam, 9 PSI Etc.......... 540Rwhp/542Rwtq
    Oct 2009
    Nebraska
    46
    Finished the Auto C7 completely stock tune only on a MD1100 Mustang Dyno
    386/384wtq SAE Stock
    409/406wtq SAE tuned
    Still getting some random KR that Im sure is false knock. Its not much about 1.3-.8
    Still need to work on the Transmission Calibration a little more on it.
    Mar 2010
    Texas Hill Country
    3,299
    OP log your ETC, it is probably closing. You can keep it open through Driver Demand table in Engine/TqMngmt and possibly Peak Torque.
    6spdGTO, how much timing are you commanding at WOT?
    Oct 2009
    Nebraska
    46
    17-21 @ WOT
    I had less timing in the manual c7 but got away with 20-21 on the auto
    Nov 2009
    All Around
    3,149
    Good gains, what fuel you running through it
    Quote Originally Posted by 06x6spdGTO View Post
    Oct 2009
    Nebraska
    46
    Quote Originally Posted by SultanHassanMasTuning View Post
    91 octane
    Both cars had less then 50 miles on them. I'm sure the more they break in there would be more gains
    Mar 2010
    Texas Hill Country
    3,299
    That's great for 91. I'm on 93 with an M7 and can only get 16-18 at wot. On MS103 I can run the Max Torque Timing table figures without issue....like 25.
    Dec 2008
    on the Dyno
    1,825
    The last one I did had bolt on's, cold air, and Kook's Headers and X-pipe and on the stock tune made 390rwhp on our dyno dynamics and after tuned came up to 430.1hp. This was on 93 octane shell. I was able to get around 21* at peak tq and up to 23-24 at redline. This was a manual car. In my past experience relieving the restriction on the exhaust allows a bit more timing than a stock manifold/cat setup would.
    Located in Central Kentucky
    ShorTuning
    Oct 2009
    Nebraska
    46
    Quote Originally Posted by LSxpwrdZ View Post
    James,
    How was the fitment and installation on the Kooks?
    Did you still get some random case of false knock at all, about 5000-6200 rpm randomly?
    Jul 2012
    Italy
    219
    What AFR are you targeting for?
    Oct 2009
    Nebraska
    46
    With the Auto I was shooting for 12.5 AFR, Manual was 12.7
    Should have a Stainless Works LTs, OR-X pipe, CAI Manual in later this week
    Jan 2012
    tampa,fl
    64
    Just fyi ive installed 3 kooks and about 7 arh c7 header/x pipes threw my work. The Kooks have a higher end look and also a gold finish where the arh are just silver. The kooks fit/install easier, you dont have to remove the dry sump lines on those equipped cars and have a better catted x pipe design. The ARH headers are less expensive, fit good, good customer service,make the same power, but you do have to remove the dry sump lines to install. The overall power gains were the same but 3/4 arh's made a 5ish more midrange tq.
    I have had almost no time to come back to this. So I don't have any new logs.
    I had checked the blade position when I was messing with the tune, and it was not closing.
    I did get a chance to put an aFe intake on the car. Did a quick pull at the end of a dyno day I hosted, and it now put down 445rwhp. No log. I was in a rush.
    Stock it did 402rwhp, and with headers and messing with the tune put it at 415rwhp.
    I changed the driver demand tables when I was messing with the tune but not the peak torque tables.
    It seems that in my crappy air, this car REALLY needed the intake side opened up.
    I hope to get back to it in a few weeks.
    Oct 2009
    Nebraska
    46
    Got the stainless works put on a Auto C7... Made 388 Stock. Hopefully have it on the rollers soon with some good results. Just doing Headers and a Tune no CAI yet.
