We Have installed a GM Performance LS3 crate motor in a 1992 Camaro with a t56. What needs to be changed for the tach to read correctly. And does anything else besides the gear ratio and tire size need to be changed for speedo to be accurate
69 Suburban Bagged & Blown: http://67-72chevytrucks.com/vboard/s...d.php?t=200387
68 Farm Truck build thread-LS3/6L80/TVS1900: http://67-72chevytrucks.com/vboard/s...d.php?t=358692
Thanks! I will try the tach out in the mourning in the mourning. I did not see where I could change the speedo setting. I did the update this mourning. I had seen the thread. Does the blue cat stuff work on windows 8
